OUCH
either way its goin to cost him the same amount for labour to weld the oil pan. u still have to remove it,weld it,test it to make sure it doesnt leak even then its not a full garente. it will take lease time to just put out the extra couple of bucks to get a new one.
You really don't need to take the bottom sub frame out. Just loosen your motor mounts and jack the engine up. I changed mine last month on a 01 a4 1.8 and that worked for me... Just don't forget about those two back bolts, Thats what held me up when I changed mine, I couden't figure out why the pan wouden't fall eventhough I had taken all of the visabel bolts off. By the way you will have to turn over your engine to spin the flywheel to get the two back bolt off ( use a socket and turn it by hand). Make sure you have a long extension and the correct star bit for the back bolts.
