OUCH
Old May 9, 2006 | 10:10 PM
michal's Avatar
Member
Default RE: OUCH
get it welded by a profesional welding shop that has equipment to weld aluminium. cheaper.. trust me
Old May 10, 2006 | 01:08 AM
TeeterTawter's Avatar
Default RE: OUCH
either way its goin to cost him the same amount for labour to weld the oil pan. u still have to remove it,weld it,test it to make sure it doesnt leak even then its not a full garente. it will take lease time to just put out the extra couple of bucks to get a new one.
Old May 10, 2006 | 01:49 AM
michal's Avatar
Member
Default RE: OUCH
oooookkkk
Old May 10, 2006 | 04:07 AM
A4PLAYIN's Avatar
Default RE: OUCH
ORIGINAL: michal
oooookkkk
wha ha ha.......... i'd think it would be cheaper to jus get that s#!t from ecs tuning..... IMHO
Old May 10, 2006 | 05:07 AM
BadLuckAudi's Avatar
Default RE: OUCH
thats why we need those crazy strong steel skids that someone makes so squirrels and small holes dont break our oil pans
Old May 10, 2006 | 10:30 AM
cas4067's Avatar
Default RE: OUCH
You really don't need to take the bottom sub frame out. Just loosen your motor mounts and jack the engine up. I changed mine last month on a 01 a4 1.8 and that worked for me... Just don't forget about those two back bolts, Thats what held me up when I changed mine, I couden't figure out why the pan wouden't fall eventhough I had taken all of the visabel bolts off. By the way you will have to turn over your engine to spin the flywheel to get the two back bolt off ( use a socket and turn it by hand). Make sure you have a long extension and the correct star bit for the back bolts.
barney12
Mar 13, 2012 11:37 AM
chuckievi
Aug 23, 2006 12:01 AM
