OUTER CV BOOT REPLACMENT HELP
Old Jul 24, 2007 | 07:40 PM
x650rwc650x's Avatar
Default OUTER CV BOOT REPLACMENT HELP
hey so i got to change my right outter front CV BOOT. I looked at it today its really tore up and left a mess of grease build up in my rim i can now see iside the boot there still lil grease on the metal part insdie but all the grease came out so thinkin bout duin it my self. talked to my mechanic said he was only going to change the rubber boot not the axle and is charging me $100. it dont look to hard seen the cv boot kit at kragen auto for $17. so instead of paying $100 THINKIN DOING IT MYSELF. dontlook to hard just the rubber boot and2ring clamps and fill it with grease. so i dont need to take off the axle right???? and how should i clean around it ???ANY TIPS 2 make sure i do right.and is the rubber boot kit reliable. heard i was just going to end up at the shop in 3months or so WHAT YOU GUYS THINK???
Old Jul 24, 2007 | 07:44 PM
auditech79's Avatar
Default RE: OUTER CV BOOT REPLACMENT HELP
Do NOT buy anything from autozone for a cv boot repair.
The entire outer cv boot repair kit is around 60 bucks at the dealer and comes with
a new boot, center hub bolt, clamps, crush washer, and snap ring.
You need to rent either a slide hammer or a gear puller to get the outer cv joint off the shaft, other than that its all basic tools.
Old Jul 24, 2007 | 07:59 PM
khj677turbo's Avatar
Yeah, go do the dealer! Its all you need in one kit. And I thought you had to take the whole axle off? But im not sure.
Old Jul 24, 2007 | 08:01 PM
auditech79's Avatar
Nah, we usually don't take off the whole axle, its easier to just take it out of the hub and suspend it with a bungie cord then bang off the cv joint.
Old Jul 24, 2007 | 08:41 PM
So can you give me a quik discriptionof what to do. and how to clean it
Old Jul 24, 2007 | 09:24 PM
auditech79's Avatar
Sent you a PM of the info.
Old Jul 25, 2007 | 05:29 AM
so ive been driven with the cv boot tore can see that alot of the grease came out and pretty sure dirt has got in there how should clean the dirt that inside?
rehan1212
Aug 22, 2013 07:28 PM
BlackQuattro
Apr 30, 2009 09:33 AM
jonnyblazz1
May 14, 2008 10:48 PM
heloman28
Apr 19, 2008 09:33 AM
craig_mack
Oct 19, 2006 02:49 PM
