noob looking for tools needed to replace outer cv boot on B5
Old May 12, 2008 | 05:09 PM
jonnyblazz1's Avatar
Default noob looking for tools needed to replace outer cv boot on B5
Yeah, its torn. I want to do it myself and probally have all the tools except for a large socket for the center bolt. What nees to come out and some wrench sizes would be a help. Thanks
Old May 14, 2008 | 03:15 PM
Default RE: noob looking for tools needed to replace outer cv boot on B5
Oh man, no love.. I really feel like a noob. I did my 96 a4 rear shocks and front control arms and inner tie rod. The s4 is new to me and just looking for a tip. Bringing it to a mechanic is not the tip im looking for.
Old May 14, 2008 | 09:26 PM
drev500@aol.com's Avatar
basic metric wrenchs and an allen wrench for the abs sensor i forget which size but around a 7mm. some sockets a little know how and a crimper for the boot clamps. Oh and a big *** breaker bar for the axle bolt. Thoes puppies are torqued down pretty good and need to be torqued to 100ft. lbs. plus another 180 degree turn. http://www.audiworld.com/tech/misc27.shtmljust to sum it up
Old May 14, 2008 | 10:48 PM
Artrip's Avatar
^^ thats the hard way^^^
Easy way:
Pop center cap off of rim, remove hub bolt.
Jack up car, take off tire, unbolt caliper, support it on something, so its not hanging from the wires. the ABS sensor does NOT need to come out.
Take out bolt in upright that holds the two control arms on, pop them out.
Unbolt two bolts holding tie rod on, take it off as well.
wiggle axleshaft out of upright, fiddle with it, it will come out @ the right angle.
Cut old boot off.
Use the old hub bolt as a pusher, run it in until it pushes the CV joint off.
Clean the joint up, replack with grease, put the new boot on the axleshaft.
Use the plastic cone thing to hold the C clip down, let one end of the c clip show, push it down, and slide the joint down on the splines until it hits this end, push the end into the groove, and get the joint started over the clip.
Take a hammer and a block of wood, place the wood against the hub splines of the joint, and give it a good whack. It will jump over theC clip easily, since the plastic clip was holding it down, and you took the time to get it started under the joint on one side (learned this trick the hard way, lots of swearing).
Reassemble everything else.
rehan1212
Aug 22, 2013 07:28 PM
chickeneater
Dec 7, 2010 12:41 AM
heloman28
Apr 19, 2008 09:33 AM
x650rwc650x
Jul 25, 2007 05:29 AM
craig_mack
Oct 19, 2006 02:49 PM
