Plugs
Old Dec 3, 2006 | 10:33 PM
xAUDIx's Avatar
Default Plugs
Hey i did a search but nothing came up.
Is there a DIY for changing the spark plugs on a 98 2.8 30v?
And do you have to change the wires when u do the plugs too?
Old Dec 3, 2006 | 10:49 PM
Karl's Avatar
Default RE: Plugs
If you have ever changed plugs before.. then it should be very simple.. here is a writeup for ya..
Step 1: Remove plug
Step 2: Gap new plug
Step 3: Insert new plug
No you dont have to change the wires everytime.. do you do that with any car?
Old Dec 3, 2006 | 10:50 PM
Bondga's Avatar
Default RE: Plugs
make sure you torque the new plug to the right specs. not shure what it is but probably somewhere around 19ft-lbs
Old Dec 4, 2006 | 01:41 AM
Turbulence's Avatar
Default RE: Plugs
on the topic of plugs, what performance plugs would you guys reccomend?
Old Dec 4, 2006 | 08:37 AM
david9999's Avatar
Default RE: Plugs
OEM NGK plugs.
And make sure you use some antisieze compound on the threads and don't over torque the plugs. You will thank yourself in 30K miles.
Old Dec 4, 2006 | 02:08 PM
new2me's Avatar
Default RE: Plugs
http://www.a4mods.com/index.php?page...pperplugs.html
This might help a little.....
Old Dec 4, 2006 | 03:36 PM
klum00's Avatar
Default RE: Plugs
any recommended plugs for the 12v? NGK BKR6E's?
Old Dec 4, 2006 | 03:44 PM
new2me's Avatar
Default RE: Plugs
There are threads on this i cant remember which # (6 or 7) to use. If you are chipped one is recomended and if your stock a different # is recomended.
Old Dec 4, 2006 | 06:08 PM
rayveedub's Avatar
Default RE: Plugs
i ditched NGK a while ago and now only run and endorse Denso iridiums, hey you get what you pay for.
briesa4
Mar 18, 2010 04:13 AM
sony
Mar 3, 2009 06:16 PM
madridlover
Dec 23, 2008 06:27 PM
99A6Q
Feb 13, 2008 02:33 PM
mainer
Feb 20, 2005 02:57 AM
