Power Steering Pump Noise!!??
Old Feb 20, 2006 | 08:54 PM
mikehh's Avatar
Default Power Steering Pump Noise!!??
Anyone that had a noisy power steering pump?? Especially when its cold, its humming like a buzzbomb. I thought of changing the fluid? will that help or should I go for a new pump?
Old Feb 20, 2006 | 09:15 PM
Polyweiser's Avatar
Default RE: Power Steering Pump Noise!!??
Probably low fluid which probably also means you have a leak somewhere. Mine did that and I topped it off and then it started again a month later so I knew it was a leak. Ended up being just a hose coming out of the resevior. Although, it did cost $65 from the dealership!
Old Feb 20, 2006 | 09:48 PM
kakarot's Avatar
mine does a rateling noise. I top it off and it continues. I use Universal ATX oil.
Old Feb 20, 2006 | 09:59 PM
mikehh's Avatar
well, fluid level is fine, and i see no leaks anywhere... would you use mineral or synthetic oil??
Old Feb 20, 2006 | 10:18 PM
sandnsnow24's Avatar
got the same prob. excpet mine loses power at low rpms.... feels like manual steering
I'm thinkin of just pulling it and runnin full manual steering [8D]
is it just me or are those d*mn sponsered links HELLA annoying
Old Feb 21, 2006 | 12:14 PM
hb972.8q's Avatar
when its cold out mine usualy makes that noise. it also makes that noise when it low i an losing fluid through multiable lines. dont feel like replaceing them so i just keep adding oem fluid when it gets low.
Old Feb 21, 2006 | 02:33 PM
avanttripleloop's Avatar
you should stick with the audi green mineral for steering.
juju4uofa
Mar 12, 2013 07:03 AM
hartsoe1
Aug 1, 2012 08:31 AM
sunilmsahoo
Jan 22, 2011 07:13 PM
guru_stu
Dec 5, 2010 01:48 PM
pwonder
May 3, 2009 01:45 PM
