Rear rotor replacement
Old Aug 12, 2004 | 05:37 PM
dudley doright's Avatar
Default Rear rotor replacement
I was told that a special tool is needed to retract the piston of the rear caliper. Does anyone know what this tool looks like and where I could get one? Your advise is very much appreciated.
Old Aug 12, 2004 | 06:17 PM
CRAZYHAWK's Avatar
Default RE: Rear rotor replacement
Are you replacing the pads? If so, you can use needle-nose pliers to turn the rear pistons clockwise.
Old Aug 12, 2004 | 06:42 PM
Jestnomen's Avatar
6th Gear
The rear piston tool can be found at most auto parts stores. I think I bought mine at napa for like 10 bucks.
Old Aug 12, 2004 | 10:09 PM
Doose's Avatar
Yeah, you can get them at pretty much any parts store cheap. Brakes on A4's are pretty easy, you can definitely save some coin doing it yourself. While you're at, it you might want to change your brake fluid too.
Old Sep 1, 2004 | 04:14 PM
tbrumley's Avatar
The rear piston needs to be turned to go in, while the front can be pushed in with brute force. The NAPA part mentioned below, I also purchased fro around $10.00. It is the GM-Ford Disc Brake Piston Tool, part number 3355. You can use your rachet to attach to this part, it will help give you more torque. Hope this helps..
2000 A4 1.8T
Old Sep 1, 2004 | 04:56 PM
David_K's Avatar
you can get the tool for free from autozone
Old Sep 2, 2004 | 01:39 AM
SlimChriz's Avatar
LOL like the new sig David...
KRT_A6_2013
Aug 9, 2015 02:07 PM
tomplace
Audi Q5
Nov 9, 2011 11:24 AM
james0013
Oct 7, 2008 12:23 PM
kbunting
Jul 15, 2007 09:11 PM
