remote for A4
my remote control stopped working the other day. my spare works. i just replaced the battery on my remote for the first time. however,it doesn't work. do i have to program it or do i need to replace it?
thanks
thanks
Sorry to belabour this reprogramming issue. After replacing the batteries in the remote for my '96 A4, I tried the procedure you describe, but it does not seem to work. Is there a different procedure for my model and vintage?
check this post:
https://www.audiforums.com/m_4743/tm.htm
or
https://www.audiforums.com/m_33706/m...y/tm.htm#35969
Also how many times did you try? The first time I tried to program my remote it took me about 5-10 minutes to get it right. Just be patient, follow the instructions and it should work.
or
The 1996 remote is different IIRC:
1. Put 1 key in the ignition and turn it on. (Don't start the car, just turn it on until the dash lights up. )
2. Roll down driver's side window. 3. Take the second key and lock the car using the drivers door.
4. Hold BOTH buttons on the remote until the turn signals flash and the door unlocks. It should take about 5 seconds or less.
MartinCieslak1
Dec 11, 2009 02:30 PM
