remote for A4
Old Dec 5, 2004 | 08:01 PM
lizmarie's Avatar
Default remote for A4
my remote control stopped working the other day. my spare works. i just replaced the battery on my remote for the first time. however,it doesn't work. do i have to program it or do i need to replace it?
thanks
Old Dec 5, 2004 | 08:10 PM
Jestnomen's Avatar
6th Gear
Default RE: remote for A4
You have to reprogram the remote after replacing the batteries. I have posted directions in the "General Tech" forum.
Old Feb 18, 2005 | 01:05 AM
96a42.8's Avatar
Sorry to belabour this reprogramming issue. After replacing the batteries in the remote for my '96 A4, I tried the procedure you describe, but it does not seem to work. Is there a different procedure for my model and vintage?
Old Feb 18, 2005 | 01:28 AM
jason745's Avatar
check this post:
https://www.audiforums.com/m_4743/tm.htm
or
https://www.audiforums.com/m_33706/m...y/tm.htm#35969
Also how many times did you try? The first time I tried to program my remote it took me about 5-10 minutes to get it right. Just be patient, follow the instructions and it should work.
Old Feb 18, 2005 | 02:10 AM
Jestnomen's Avatar
6th Gear
The 1996 remote is different IIRC:
1. Put 1 key in the ignition and turn it on. (Don't start the car, just turn it on until the dash lights up. )
2. Roll down driver's side window. 3. Take the second key and lock the car using the drivers door.
4. Hold BOTH buttons on the remote until the turn signals flash and the door unlocks. It should take about 5 seconds or less.
Old Feb 19, 2005 | 01:58 PM
96a42.8's Avatar
Thanks, it worked!
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
Albee G
Mar 9, 2008 08:21 AM
marcink99
Jan 26, 2008 10:09 PM
