Remove Front Speaker Grill
Old Nov 28, 2007 | 10:35 AM
cjh91's Avatar
Default Remove Front Speaker Grill
I recently purchased a 2006 A4, and ever since, I've been hearing a rattling noise behind the driver side speaker grill when driving. When I tap on (the speaker grill), or around it, it sounds as if something is loose. My question is, can I remove the speaker grill itself, or do I have to remove the entire door panel? Again, it's a 2006 A4 2.0T. Thanks!
Old Nov 28, 2007 | 10:51 AM
sineo's Avatar
Default RE: Remove Front Speaker Grill
I have a B5, but on mine, the speaker grill is welded or glued on and I have to remove the whole panel. I would guess you do too.
Old Nov 28, 2007 | 11:16 AM
cjh91's Avatar
That's what I was affraid of. I have seen several posts on how to remove door pannels older models, but none on newer models. Is it safe to assume that the process is the same?
Old Nov 28, 2007 | 12:53 PM
sineo's Avatar
Yeah, it's the same with all cars...you just have to find the screws and be gentle with lifting it off.
Old Nov 28, 2007 | 07:04 PM
auditech79's Avatar
No its different on all from B5 to B6 and on. B6 and B7's are very similar, your won't lift off like the B5 will. You have to remove the trim on the top and remove the 4 screws there, remove the little plastic panel under the door handle and remove two more screws, then finally remove the black screw on the bottom of the panel.
Once you have them all out wedge a screwdriver under the panel so you can get you fingers in there then grab a hold of it and pull it out really damn hard. The clips will pop (some will break) then pull the panel off the door.
Old Nov 29, 2007 | 02:33 PM
cjh91's Avatar
Great. Thanks. How difficult to remove the "wood" trim? Does it just pop off?
Old Nov 29, 2007 | 03:19 PM
jflores72's Avatar
Could this be covered on his warranty, it is a 2006 if he has a warranty??
Old Nov 29, 2007 | 06:09 PM
auditech79's Avatar
ORIGINAL: cjh91
Yeah the trim just pops off, and no it wouldn't be under warranty.
JonnyOctagon
Jul 6, 2008 11:36 PM
da_vi_man
B7 Models
Jul 6, 2008 01:26 PM
bobren4
Dec 4, 2007 02:48 AM
Plopper
Oct 8, 2007 02:13 PM
Braingears
Jul 25, 2005 03:55 AM
