Replaced Air Filter, What happened??
Old Nov 22, 2007 | 02:53 PM
picks21's Avatar
Default Replaced Air Filter, What happened??
Hello I just replaced the Air Filter on my 02 1.8t and now the check engine light keeps coming on. The codes that it gives me are PO171, (bank one too lean) and PO102 (Mass Air Flow Low Input) does anybody know why these keep coming on. I dont know if i did something wrong or what. I installed a brand new K&N filter. Thanks for any help you may have.
Brandon
Old Nov 22, 2007 | 03:54 PM
jsgrabo's Avatar
Default RE: Replaced Air Filter, What happened??
you probably got some oil on the maf from the k&n. check the maf and wipe it clean. i think that should fix your problem.
Old Nov 22, 2007 | 06:12 PM
SAudi's Avatar
ORIGINAL: jsgrabo
that would be my guess if you got a K&N or somethign similar with oil on it, replace the filter with a OEM one or similar and clean the MAF with some MAF cleaner or denatured alcohol
Old Nov 22, 2007 | 06:47 PM
hiwords's Avatar
blow dry ur filter for like 10 min or so. also do wut the others said and u'll be all good
Old Nov 23, 2007 | 10:19 PM
picks21's Avatar
Just tryed cleaning the mass air flow sensor and the same code keeps coming up. The traction control light comes on and then about two minutes later the check engine light will go. Any thoughts
Old Nov 24, 2007 | 10:04 AM
CRAZYHAWK's Avatar
My MAF went bad at 87K mi.
I would think oil from the K&N filter
is causing your problem.
skihigh2299
Sep 25, 2015 12:09 AM
T-Wall
Dec 15, 2014 01:27 PM
SmoothTT
Oct 18, 2009 09:49 AM
bada4s
B7 Models
Aug 26, 2009 12:49 AM
02A418T
Aug 21, 2007 09:43 PM
