RIM and TIRE QUESTION
Old Sep 27, 2005 | 07:33 PM
  #21
Cheese Eater's Avatar
Default RE: RIM and TIRE QUESTION
i think what needs to be answered is tire width. on the s4 it comes with 18x8 rims and a 235mm tire. if you look at technical specs on tires for example toyo http://www.toyo.com/tires/tire_specsheet.cfm?id=18 the 235mm width is good for rims from 8 to 9 inch, 8.5 being optimal. so, how wide do you want to go for friction purposes? in my past experiences, my vehicles stock tire width shorted the max by about 20 to 30mm. and if you go to that max, the rubbing will happen on turns, with pos g's or on pot holes or bumps or all three.
Old Sep 27, 2005 | 09:43 PM
  #22
headshok2002's Avatar
ORIGINAL: juju4uofa
Just so this doesn't keep coming up, tire diameter is calculated like this:
225/40R18
225=tire width in milimeters
40=aspect ratio; each sidewall measures 40% of the tire width (225mm) don't forget there are two sidewalls
18=wheel diameter in inches.
So for the overall diameter:
(225*.40*2)/25.4+18=25.09in
Height of both sidewalls divided by 25.4 (number of milimeters in one inch) plus the wheel diameter equals total tire diameter in inches
That's all well and good... but please note that different manufacterers and different models will yield different diameters as well. If only it were so simple as the formula! But yeah, not all... say... 225/40/18's have the same diamter... usually close to 1/2" in difference from one end of the spectrum to the other.
When I bought tires for my golf, clearance was a huge issue... I needed 215/35/18's... and actually checked all the tire manufacters to find out who made the 'smallest' 215/35/18's. I ended up with the ventus k104, which sucked ***... but, even it rubbed a lot. Thank god I didnt get a bigger tire.
Old Sep 28, 2005 | 06:25 AM
  #23
OS's Avatar
OS
I thought about getting coilovers, but since this is going to be my girl's car, I think I want to go the most economical way possible. I was hoping to get some insight as to what brands will yield me the lowest drop.
Old Sep 28, 2005 | 01:19 PM
  #24
19's aren't exactly "economical"... neither is finding the widest tire you can fit in the back.
You can buy a spring/shock setup... but who knows, you might sit too high, or too low.
99a4wagon
Oct 30, 2010 11:50 PM
johnstef
Apr 13, 2008 01:48 PM
turbowonder
Jun 13, 2006 08:58 PM
west2005
Mar 8, 2006 04:29 PM
tom2005
Oct 23, 2005 11:50 AM
