signal lights problem
Old Sep 16, 2006 | 05:47 PM
techbod's Avatar
Default RE: signal lights problem
English - V - American its a language thing
Old Sep 16, 2006 | 05:50 PM
techbod's Avatar
just look for hazard warning switch not that expensive through the dealers
Old Sep 16, 2006 | 06:16 PM
cobra91's Avatar
sory to spend your time much.. but just to be sure; my problem occurs while I signal to the left or light.. when I press the hazard warning ligth switch It's ok. I have no problem with the working of the hazard warning ligths . I want just to be sure if it is the correct part I need to change.. THANK YOU...
Old Sep 16, 2006 | 07:17 PM
socal_A4's Avatar
i know you have no problem with the hazards but the turn signals are controlled by them too... honestly to put it plain and simple you need a new hazard switch aka relay switch... Go to your dealer because I highly doubt ebay will have them and there relatively cheap at the dealer.... pop out the trim out around the switch with flat head then proceed to take out the hazrd button... its really easy to do you can do this... read what I just said then go out to your car and do it... youll be surprized how the trim around it just pops right out ten simply take a look at it and you will see the 2 prongs that you push in and then slides right out unplug plug new one back in put the trim back in and your good to go... it should take you no more than 10 mins
Old Sep 16, 2006 | 09:36 PM
cobra91's Avatar
Thank you so much.... you explained it in details. ALL CLEAR.... Thank you DAVE and Thank you SOCAL_A4....
Old Oct 9, 2006 | 11:08 PM
shur1k's Avatar
Hi..my name is alex..and im a new member here ..and i dont know nothing about audi's and i would love to learn it all..if i could.. but first.... I half way bought an 96 audi a4 v6 seems like a nice car..just one little problem ..my signal lights dont work properly..one blink then stops..other times dont work at all....and same on the indicator panel ..should i exchange ("the hazard warning light")
?? ..is it the same problem as you guiz descussed it higher..?????
This Audi has 117 miles on,.. it has problem with the klutch as far as i know or guess..and i havent taken'it to do the diagnostics..
and i have spotted 11 things i should replace inside the interior.. can someone help me deside should i buy this car or not...i would appreciate very much your recommendation..since i have no clue what im buying..thanks
Old Oct 10, 2006 | 12:10 AM
ultrasport's Avatar
welcome to audi cars mint electric sucks
Phat_J
Feb 18, 2012 01:32 PM
konboy22
Jun 9, 2011 01:01 PM
tims_S6
Dec 30, 2009 06:41 PM
dtkelley2005
Sep 25, 2007 12:22 AM
sautsinaga
Apr 8, 2007 12:52 AM
