SLight Whine from tranny
Old Sep 13, 2007 | 01:21 AM
Audi_Skydiver's Avatar
Default SLight Whine from tranny
This just started happening a bit ago and I figured I would look into it especially since I will be adding additional stress to it here pretty soon with the bigger turbo.
Problem: Every so often when I am stopped and in drive the car makes a little bit of a whine noise that is coming from the tranny. If I shift into neutral then it goes away and everything else works great. It shifts a little hard every so often but it's VERY rare. Should I do a transmission fluid change?
Thanks for the help!
Josh
Old Sep 13, 2007 | 08:18 AM
david9999's Avatar
Default RE: SLight Whine from tranny
It is hard to see your car info in the picture, but you look like a 99.5.
Yes I would suggest a fluid change with OEM fluid. You might even consider dropping the pan and doing a full change and changing the filter.
pinion
May 14, 2015 06:51 AM
aeeroN
Jun 5, 2012 10:02 PM
alxjhn
Sep 6, 2010 10:49 PM
Siren
Aug 8, 2008 09:41 AM
Meyer193
Nov 15, 2007 07:18 PM
