Some problems that are starting to get annoying.
thanks.
i'll get it scanned at autozone next time.
my brake fluid is pretty high, i'll double check just to make sure.
my car makes a long beeping noise when i turn the lights on period, it will make a long beep for awhile. no idea whats wrong with it.
yeah i found it strange how it only showed up 1 rear fog light in the owners book.
if i get a key, i could get them cut at any key cutter right?
i tried to reset the service inspection today, i searched it and this is what i found.
"press and hold button uinder the tach then turn ignition on ( do not start engine ) then release and turn button under the MPH to the left ( while ignition on till you see 10,000 in the odometer then switch ignition off and your done"
it didn't work
i don't know if i'm doing it right or not. sigh ..
it didn't work
I have a similar problem with my ABS light (it just stays on) I brought the car to autozone to get it scanned, but it didnt display any fault codes. Maybe it was not coordinated with the airbag module and only the engine...have you gotten yours scanned yet?
i got mine scanned, but i didn't know i could get it scannd for free at autozone so the shop burned me of 80$ for a damn scan. eh oh well. i thought you could only scan for engine check or whatever, i'm gonna bring it there and check it though.
Smokin Tubes
Feb 5, 2012 10:11 AM
gilee_8
Sep 23, 2006 10:12 AM
