start up
ok how do you reset it. i searched and i did what i found
put key in ignition
push and hold odometer button
turn to first click
push or pull (i did both) the clock reset button
turn ignition off.
i did it about 10 times and it did not work. so how do i reset it
put key in ignition
turn to first click
turn ignition off.
actually i got it to work. you dont need a vagcom. you push in the odometer button. then put the car on but not start it and then push and hold the clock reset button at the same time and it resets.
Onepoint8tee.....I have two lights that come on....one that says oil, and then a seperate one that says service. The oil comes on every 5000, and I don't know how often the service one comes on since I have only had it come on once. Is there a service he should be looking into performing since that light came on?
Vict0ar
Apr 3, 2014 08:38 PM
kinnes042
S4
Apr 10, 2013 06:29 PM
brit.mike13
Oct 17, 2010 08:26 PM
