start up
Old Apr 30, 2007 | 03:34 AM
b.hasz's Avatar
Default start up
so when you start up your car, do you guys have a light that flashes service and then goes away a few seconds later just like the battery light and stuff how it flashes and goes away.
Old Apr 30, 2007 | 03:37 AM
akielb's Avatar
Default RE: start up
re-set your service indicatior - check audidiy for a write-up
Old Apr 30, 2007 | 03:38 AM
onepoint8tee's Avatar
There is a procedure to reset it. Its just to remind you for service/oil change every 3k miles i think. Search "reseting service light"
Old Apr 30, 2007 | 03:46 AM
b.hasz's Avatar
ok thanks. cause when i cycle throught stuff it says everything is fine.
Old Apr 30, 2007 | 04:13 AM
b.hasz's Avatar
ok how do you reset it. i searched and i did what i found
put key in ignition
push and hold odometer button
turn to first click
push or pull (i did both) the clock reset button
turn ignition off.
i did it about 10 times and it did not work. so how do i reset it
Old Apr 30, 2007 | 04:42 AM
wood_e's Avatar
What year is your car? If it's a 97 or older that won't work - you need a vag-com to reset it.
Old Apr 30, 2007 | 07:45 PM
b.hasz's Avatar
actually i got it to work. you dont need a vagcom. you push in the odometer button. then put the car on but not start it and then push and hold the clock reset button at the same time and it resets.
Old Apr 30, 2007 | 09:11 PM
less_of_me's Avatar
Onepoint8tee.....I have two lights that come on....one that says oil, and then a seperate one that says service. The oil comes on every 5000, and I don't know how often the service one comes on since I have only had it come on once. Is there a service he should be looking into performing since that light came on?
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
