steering wheel makes a wierd noise.
Old Oct 7, 2005 | 06:06 PM
Fall0ut's Avatar
Default steering wheel makes a wierd noise.
Ok, so lately my Audi A4 started making a creeeking noise when I turn the wheel at times. Not always, but it sometimes does it.
What could this be?
Old Oct 7, 2005 | 06:11 PM
skidplatexa4's Avatar
Default RE: steering wheel makes a wierd noise.
If when you turn the wheel and it sounds like two balloons rubbing together it is the bushings on you r control arms
Old Oct 7, 2005 | 11:00 PM
david9999's Avatar
It is interior and it is the interior steering column joint. Try changing the tilt and telescopic up and down and in and out. That will at least temporarily fix it.
Old Oct 8, 2005 | 09:00 PM
sdaudi's Avatar
you could be low on power steering fluid. my steering made a low buzzing noise when i turned the wheel.
sometimes it also helps to flush out the fluid and put new one in there.
Old Oct 9, 2005 | 09:09 PM
jlaudio184's Avatar
def power your power steering fluid, get the mineral oil only tho!
o0hmikee
Nov 10, 2012 08:21 AM
newhandle
May 16, 2011 11:51 AM
dirtybird82
May 26, 2010 02:09 AM
ruby
Apr 15, 2007 05:27 AM
Caylin
May 12, 2005 09:02 AM
