Steering wheel shakes when braking..
Old Oct 12, 2007 | 12:58 AM
Sp33d07's Avatar
Default RE: Steering wheel shakes when braking..
well i had a smiliar problem, but mine was loose pad, the clips that were spossed to be in the pistons sum how popped out on the drivers side, it would click everytime i tap the brakes and my steeringwheel would shake when i brake.
Old Oct 12, 2007 | 01:20 AM
Trey25's Avatar
If you're gonna turn/resurface or just replace the rotors change the pads as well. Have them check the run out first though.
Old Oct 12, 2007 | 11:33 AM
ironman's Avatar
ORIGINAL: sdsteez
ORIGINAL: jonsaudi
(cost $135 btw for oil change)
i hope youre kidding!! can you really not unscrew one bolt to drain your oil and take your right hand and unscrew the filter? you could have done 3 synthetic oil changes yourself for that much
Did any one else see this??
Old Oct 12, 2007 | 12:10 PM
The Russian's Avatar
yeah thats rediculous. i haven't paid anyone to do an oil change in... ever.
Old Oct 12, 2007 | 01:07 PM
Papachristou's Avatar
yeah x23 on the warped rotors.. b6s are known for it...
audi warrantied my rotors then the second time, i went aftermarket
i would get some aftermarket cross drilled or slotted or both depending on your preference, some say drilled crack but i think that was back in the day or if u track your car heavy... i have both just for looks.... slots do use pads slightly quicker though... but keep the fade down and help in the rain too
but do the rotors with some kinds CD or slots or plain is fine too
get some better pads like mintex redbox,hawk hps pbr... search around to see what ppl say,. i have hawk ceramics and they are spongy till they are warmed up but very very little dust
also if u got the $ do stainless steel lines and some motul 5.1 (bettter) fluid and it will improve the feel 100%
Old Oct 12, 2007 | 05:48 PM
ImTheDevil's Avatar
I'd suggest checking lug torque too - if the last person to take the wheels off put them back on and just grape-aped the lugs without using a torque wrench, unequal torque on the lugs could slightly distort the rotors and create the pulsation (had it happen to me before). It's probably going to be rotors themselves, but this is worth checking into - if you have a torque wrench, it's free.
Slickjr
Jan 25, 2013 02:01 PM
dpc1192
Nov 16, 2009 11:31 PM
A4in808
Apr 28, 2006 12:29 PM
hypnotiks
Mar 14, 2006 02:30 AM
