strange front-end noises
Old Apr 12, 2006 | 09:38 AM
jake_beahan@hotmail.com's Avatar
Default strange front-end noises
I just bought a 1997 A4 2.8 5-speed manual Quattro (one owner, 129,000 miles). When I drive very slowly and turn left or right, the front-end makes a loud, high-pitched, whining noise. It sounds as if it's the all-wheel drive or the steering. The power-assist steering fluid was low, so I filled, but no help. Any ideas, solutions? I can't have it looked at at an Audi dealer until Fri. 4/21. Thanks -- Jake
Old Apr 12, 2006 | 01:00 PM
BFlan2001's Avatar
Default RE: strange front-end noises
sounds like your power steering pump might be going bad...try turning your wheel with the car totally stopped, does it make the same noise but louder?
Old Apr 12, 2006 | 01:22 PM
Russ03A4's Avatar
ORIGINAL: bentframe
Agree. What kind of P/S fluid did you use? May make it worse.
Old Apr 12, 2006 | 03:08 PM
cuda6bbl's Avatar
Sounds like a wheel bearing to me.
Old Apr 12, 2006 | 03:18 PM
Russ03A4's Avatar
ORIGINAL: cuda6bbl
...high pitched whining noise....you think so? Especially since he said the P/S fluid was way low. It's worth checkin' out though with that milage.
Old Apr 12, 2006 | 04:02 PM
tip5's Avatar
I had the same problem with my ps it was the fluid amazingly low i topped off and a month later it did the same thing. I had a very small leak in the system so more than likely its the ps
Old Apr 12, 2006 | 11:53 PM
BFlan2001's Avatar
if you added regular old power steering fluid, you're probably going to have some pretty major problems...BUT, if you added Pentosin 11S or an equivalent, and it's still making the whining sound, then your power steering pump is probably going out....that whining sound, at first, was your pump running dry..but after a while, it killed your bearing in the pump, which is most likely why the noise didn't go away after you added fluid.
Old Apr 12, 2006 | 11:54 PM
djlouieboom's Avatar
i had the same on my 01 1.8t ended up replacing the rack and all problems were solved
Spireblade
Jun 15, 2012 12:03 PM
scotts custom
Apr 21, 2009 07:22 PM
AML 225
Sep 27, 2006 12:09 AM
madridlover
Jul 22, 2006 07:07 PM
yoon
Jun 15, 2004 12:33 AM
