Stripped screw on head
Old May 15, 2013 | 03:44 PM
Expplucky's Avatar
Default Stripped screw on head
so that area under the valve cover i need to take off in order to replace the cam sensor (driver side back left close to the intake)
had a STRIPPED SCREW and my usual effective methods involve large amounts of metal shavings...is there anything i can do that doesent get metal shavings all over the place...and if you suggest hammering a torx in dont bother.
so far im thinkin hammering a chizle and having a friend hold a hose from my vaccum to suck up shavings as i go but i still feel like this will get **** everywhere?
Old May 15, 2013 | 06:15 PM
CryptoStorm's Avatar
By stripped screw it sounds like you mean the head of the screw, correct? You could get a small ezy-out and drill a small hole to extract the screw.. Or you could just drill off the head of the screw and remove the bolt once you have the cover off..
I wouldn't hammer anything (potentially) into the head
Old May 15, 2013 | 08:46 PM
2000quatA4's Avatar
Weld a junk impact to it and ratchet it off
Old May 15, 2013 | 10:43 PM
Expplucky's Avatar
welding around pooled oil?
A6boat
Dec 10, 2020 04:46 PM
tartar
May 14, 2012 01:01 PM
Import Wrencher
Dec 28, 2011 04:00 AM
a2thy
Dec 19, 2009 01:57 PM
jonsaudi
Jan 10, 2008 10:40 PM
