Temp. issue
Doubt that autozone will pick this up.
Possible problems are
1. Fans. If the engine is warm and the AC is on, check the secondary electric cooling fan at the radiator. This often burns out. If it is not spinning with the engine at operating temperature and the AC on, that is likely your cause.
2. Bad thermostat.
3. Failing waterpump.
4. Low fluid (check the expansion tank when the engine is cold.)
5. Failing water pump.
2. Bad thermostat.
