Temp. issue
Old Oct 24, 2007 | 01:26 PM
Rob_B's Avatar
Default RE: Temp. issue
Thanks, and glad I could help. Be sure to post results when you figure it out/fix it.
Old Oct 24, 2007 | 07:51 PM
david9999's Avatar
Doubt that autozone will pick this up.
Possible problems are
1. Fans. If the engine is warm and the AC is on, check the secondary electric cooling fan at the radiator. This often burns out. If it is not spinning with the engine at operating temperature and the AC on, that is likely your cause.
2. Bad thermostat.
3. Failing waterpump.
4. Low fluid (check the expansion tank when the engine is cold.)
5. Failing water pump.
Old Nov 14, 2007 | 12:44 PM
03A41.8T's Avatar
Forgot to post this the other week. It was my fan motor, once they replaced that I was good to go, now the fans are operating correctly. Thanks for all the help.
rehan1212
Apr 25, 2012 11:22 AM
rbmcveigh
Feb 8, 2011 05:05 PM
bristolTT
Nov 3, 2010 08:55 PM
williamlg
Aug 3, 2008 03:22 PM
kaklexicon
Oct 2, 2006 10:30 PM
