Temperature Reading Messed Up
Old May 26, 2006 | 11:31 AM
damir21's Avatar
Default Temperature Reading Messed Up
the temperature was goin up to the max so i went out and checked it out, a shop replaced my timing belt water pump and the thermostat and all that stuff,
now from time to time my temp is going below the half to the left towards the cold.
is it the sensor or sumting else?
Old May 26, 2006 | 12:06 PM
north5995's Avatar
Default RE: Temperature Reading Messed Up
Is it dipping below normal after the car is warmed up? If you start the car, it'll gradually make its way up to normal. If the needle starts dropping while you are driving, you may have a problem. You can check to make sure the sensor is seated properly. Check your fluids and make sure they are topped up.
Old May 26, 2006 | 12:23 PM
damir21's Avatar
yea after it's warmed up, when i turn my A/C on it starts to go down and i think my freon is low
Old May 26, 2006 | 12:51 PM
CRAZYHAWK's Avatar
Replace the temperature sensor.
Old Jan 4, 2008 | 12:35 PM
nexusgroove's Avatar
where is the tempperature sensor on a A4 2003?
thanks????
NEXUS
rbmcveigh
Apr 22, 2011 11:28 AM
sadik666
Dec 10, 2010 04:34 PM
ebattilana100
May 31, 2009 03:58 AM
brynmawr6
Aug 29, 2005 03:15 PM
A4Petro
Aug 3, 2005 09:07 PM
