Test pipe question
Old Jan 13, 2008 | 08:34 PM
BLK_A4's Avatar
Default Test pipe question
OK i know this has probobly already been asked but if i get a test pipe will i pass emissions? And what is the differnce between a down pipe and a test pipe?
Old Jan 13, 2008 | 08:45 PM
CIA's Avatar
CIA
Default RE: Test pipe question
You will not pass emissions. A test pipe its a simple pipe with 2 flanges. From the reading i did you will also get a CEL.
Old Jan 13, 2008 | 08:53 PM
chaos92287's Avatar
depends if the place you go can test AWD cars. if they can't test ur car under load, and you clear any codes before going or do the non-fouler mod, you will pass.
Old Jan 13, 2008 | 08:55 PM
chaos92287's Avatar
and you wont get a CEL if you do the non-fouler mod or angle block https://www.audiforums.com/m_732015/tm.htm
Old Jan 13, 2008 | 09:06 PM
CIA's Avatar
CIA
I also intend to get rid(well...put away until need) of the cat.
Oh, i missed that mod. It will be useful for me.
thx
Old Jan 13, 2008 | 11:40 PM
pimptrooper3000's Avatar
buddy that mod wont work trust me i tried it... u will always get the cel back. look into the shops some of them give fake tests and will pass u... might be a little more expensive but u'll be fine...if uare friends with someone who has a shop that does inspections just have them send u a sticker or inspect another car instead of urs. test pipes are amazing and u should get one
Old Jan 14, 2008 | 01:35 AM
PandaXpress's Avatar
the test pipe replaces the cat, and the down pipe is the long pipe after the cat/test pipe
you need both the test pipe/cat and down piipe
Old Jan 14, 2008 | 08:16 AM
chaos92287's Avatar
ORIGINAL: pimptrooper3000
um...yeah it does. sometimes the non-fouler's fail so you only get a CEL every 10k or so. oh noes!! if that's too hard to clear, then you don't want a tp in the first place. but the angle block actually works
Old Jan 14, 2008 | 11:19 AM
Papachristou's Avatar
ORIGINAL: chaos92287
like others have said if you can get past the visual inspection and they dont test under load you might get away with it, but i would think they would smell the unburned gas...
i did non-foulers and the CNC machined angle block and i still got an intermittent CEL from it... it would come on for a few days or a week then be off then randomly come back on....
the only permanent solution is to get REVo stage II or APR 1+ and ask for the test pipe file (that is for b6's, im not sure what options are available for b5's)
finally, though, if you can figure a way to do it or dont mind installing your cat once a year it is definitely worth it! quicker spool (im not sure how much quicker my poor k03 can spool though lower EGT's and definitely a few more HP, also my car cools down much quicker now too. Logging on Vagcom, it used to take 3-5 minutes depending how easy i drove my car the last few miles to reduce EGTs to about 400c now, it just takes about a minute......
Bob_Fangou
Jul 13, 2010 03:44 PM
gmfrosto
Sep 1, 2008 12:46 PM
sdboarder84
Jun 2, 2007 11:07 PM
Amze
Apr 14, 2007 09:55 PM
Philthykins
Jan 30, 2007 01:08 PM
