Test pipe question
and you wont get a CEL if you do the non-fouler mod or angle block https://www.audiforums.com/m_732015/tm.htm
buddy that mod wont work trust me i tried it... u will always get the cel back. look into the shops some of them give fake tests and will pass u... might be a little more expensive but u'll be fine...if uare friends with someone who has a shop that does inspections just have them send u a sticker or inspect another car instead of urs. test pipes are amazing and u should get one
ORIGINAL: pimptrooper3000
ORIGINAL: chaos92287
i did non-foulers and the CNC machined angle block and i still got an intermittent CEL from it... it would come on for a few days or a week then be off then randomly come back on....
the only permanent solution is to get REVo stage II or APR 1+ and ask for the test pipe file (that is for b6's, im not sure what options are available for b5's)
finally, though, if you can figure a way to do it or dont mind installing your cat once a year it is definitely worth it! quicker spool (im not sure how much quicker my poor k03 can spool though
lower EGT's and definitely a few more HP, also my car cools down much quicker now too. Logging on Vagcom, it used to take 3-5 minutes depending how easy i drove my car the last few miles to reduce EGTs to about 400c now, it just takes about a minute......
