Thinking of buying 1995 A4 ok car?
Old Jun 10, 2005 | 12:08 AM
cochise's Avatar
Default Thinking of buying 1995 A4 ok car?
New to Audi, looking at a 1995 A4 with 100k, other than timing belt what should I be concerned about?
Old Jun 10, 2005 | 12:11 AM
miked's Avatar
Default RE: Thinking of buying 1995 A4 ok car?
check with seller re: regular maintenance (oil, reg. service) and watch for oil sludging problem. hope everything works out
Old Jun 10, 2005 | 12:38 AM
Jestnomen's Avatar
6th Gear
1995, are you in Europe?
Old Jun 10, 2005 | 12:57 AM
Dave666's Avatar
u mean a 96 ?
Old Jun 10, 2005 | 01:39 AM
BFlan2001's Avatar
ORIGINAL: bentframe
make sure the suspension is good....worn control arms will squeak, tie rod ends will clunk when you hit bumps, cv joints will click during low speed turns (if you're on the gas), open up the oil cap to look for signs of oil sludge...do the same for the power steering fluid, as well as the coolant. sometimes people top them off or refill them with regular fluids and that can cause big problems including sludge issues....test the cruise control, the switches are known to fail (typically it's an easy fix, a good way to knock a few bucks off the price ). make sure the sunroof is fully functional as well as windows (check each door's switch individually)..listen on the freeway for a humming/grinding sound for failing wheel bearings..oh, and leave the radio OFF during the test drive, test the speakers before or after driving....also consider the mileage on the timing belt, they should be done every 60-90k miles....search the forums, there are TONS of threads on all this stuff...
Old Jun 10, 2005 | 01:42 AM
david9999's Avatar
Bentframe, you're getting lots of use out of that post.
Maybe we should stick it at the top of the forum
Audiman1991
Jun 20, 2013 12:40 PM
dmasteR
B7 Models
9
Dec 29, 2011 09:11 PM
CBR51
Oct 6, 2011 10:32 AM
KyleS4562
Sep 16, 2009 09:16 AM
