tie rods
Old Mar 10, 2007 | 11:22 PM
Belligerenceā„¢'s Avatar
Default RE: tie rods
yeah, they are a common replacement item.
Old Mar 11, 2007 | 06:10 AM
onepoint8tee's Avatar
The main problem is the seal for the balljoint. Water gets in there and dilutes the grease over time and eventually the ball joint rusts and deteriorates which creates slack in the steering causing wandering steering and a clunky sound/vibration in the steering wheel. The meyle version has a better seal/clamps around the ball joint sealto prevent that from happening at least as soon as the oem part. Plus they can handle more weight and are mechanically fail proof in their design compared to oem.
Old Mar 11, 2007 | 08:20 AM
Thumper's Avatar
ORIGINAL: Belligerenceā„¢
ORIGINAL: onepoint8tee
I highly recomend the beefy meyle TRE's. They are an improved design over stock. Check it out: http://www.purems.com/products/product.php/II=1739
$66 for 2!
I got those^ when my TRE's were shot.
Not a difficult DIY if the bolt that connects the TRE to the inner TR isnt siezed. Neither heat nor PB blaster worked for me.. I ended up taking it in to a shop where they use something hotter than propane.. Forget what its called.
it's called MAP gas. wayyyy hotter than propane.
It's actually mapP gas... I'm a picky sonofabitch, but just thought it should be said. And yes, Mapp gas is a lot hotter. About 4000 degrees hotter... Doesn't feel that good... Don't EVER try lighting a cigarette with it....
Old Mar 11, 2007 | 07:32 PM
SMoLiK's Avatar
I am getting a clunk when brakeing... Kinda' strange though, I put it in drive, hit the gas, brake and it clunks... If I hit the gas again and hit the brakes nothing happens... But if I put it in reverse and hit the brakes, it clunks... Seems like something is rocking back and forth, think this is the problem?
SMo'
Old Mar 11, 2007 | 08:14 PM
tractioncontrol's Avatar
Shops use oxyacetylene, not map gas.
Old Mar 11, 2007 | 09:19 PM
ORIGINAL: tractioncontrol
Ya thats the one!
playboy00786
Jan 23, 2011 09:01 AM
driftking8732
Apr 7, 2008 09:58 PM
Dirtbmxer2690
Jun 9, 2007 12:52 AM
voytas
Mar 29, 2007 03:17 PM
gododgers05
Mar 21, 2007 04:36 PM
