tiptronic problem
Old Oct 6, 2007 | 02:40 AM
limptimtim's Avatar
Default tiptronic problem
for some reason my tiptronic suddenly stopped working, the console display highlights P R N D 4 3 2 all at once, the car isn't shifting into 5th gear anymore, and the automatic downshift into first gear is a lot more violent..any ideas?
Old Oct 6, 2007 | 02:46 AM
Audi_Skydiver's Avatar
Default RE: tiptronic problem
Get ahold of a vag-com and run a diagnostics test on your transmission.
Josh
Old Oct 6, 2007 | 05:17 AM
david9999's Avatar
Your transmission has gone into LIMP mode to protect itself. Only 4th gear, reverse neutral and park will work.
You will need a vagcom to diagnose the problem. Could be anything from a bad TCU, to transmission problems.
Old Oct 6, 2007 | 02:40 PM
limptimtim's Avatar
of course..i forgot to make that my first order of business...
so i got only 1 code for AT (?) 293 - Multi-function Transmission Range Switch - Malfunction (PRNDL Input) (F125)
I read that this could be a result of magnets that fell out that work with the shifter..should that be the first thing to check?
Is there anything special I need to know about putting the magnets back into place?
I don't know if this is a related problem, but I saw that someone else had the exact same codes, but I am also getting the code 526-Brake Light Switch - Incorrect signal (F)
thanks
Old Oct 6, 2007 | 03:49 PM
limptimtim's Avatar
so i erased the codes and the tiptronic works even into fifth gear...i didn't open up anything to see if the magnets fell out. i am still curious as to what made it go into limp mode though.
Old Oct 6, 2007 | 06:15 PM
EVOLA4's Avatar
that's scary! Keep an eye on it and let us know how it goes.
abiv95
May 20, 2013 05:27 PM
kuven0107
Dec 9, 2011 05:40 AM
ramses
Jan 26, 2009 11:31 AM
QuickQuattro
Jun 26, 2007 07:56 PM
bAyArEaTQ
Jan 24, 2007 09:25 PM
