Tire question
Old Aug 1, 2007 | 08:41 PM
99A4NOW's Avatar
Default Tire question
Anyone running oversized tires on 16" wheels on their A4? I'm thinking about stepping up to a 215/55/16...
Old Aug 1, 2007 | 11:20 PM
ImTheDevil's Avatar
Default RE: Tire question
If you want to upsize your tires for a wider contact patch, make sure to take into account the fact that when you widen without reducing your sidewall height, you will throw off speedo and odometer calibrations (and maybe other things as well). Use this link to help you in your tire sizing (it'll help you pick a tire size that is as close to stock rolling circumference as possible):
http://www.miata.net/garage/tirecalc.html
Type in your OEM tire size and the size you're considering, and then see what kind of difference it makes, and then play with the numbers until you find something that is as little compromise as possible.
99a4wagon
Oct 30, 2010 11:50 PM
johnstef
Apr 13, 2008 01:48 PM
turbowonder
Jun 13, 2006 08:58 PM
west2005
Mar 8, 2006 04:29 PM
tom2005
Oct 23, 2005 11:50 AM
