tranny issues urgernt
Old Aug 22, 2007 | 10:30 PM
apr_a4's Avatar
Default tranny issues urgernt
i have 2001 a4 1.8t quattro tip
i have a problem with the tranny, when i put into gear they’re is a loud noise. once in a while they’re is a jerk going from 4th to 5th. some times it feels like the car is dying in first maybe because there’s a bit of water in my cone because of recent rains that could be causing the first gear issue (dropping rpm's fix it with the throttle)
my question
What is this that im experiencing?
Can it be fixed by doing a atf fluid change?
What would have causes this?
Im scared to drive so i don’t cause more damage if they’re is damage
please help me i need to get to work and to school and don’t need to loose my car do something i could have done to prevent failure
Old Aug 22, 2007 | 11:12 PM
ee99ee's Avatar
Default RE: tranny issues urgernt
are you sure it's tiptronic and not multitronic (CVT)?
Old Aug 22, 2007 | 11:19 PM
apr_a4's Avatar
was multi tronic available on the b5 sereies i dont think so because it switches hears shen making power it dosent just sit theyre
Old Aug 23, 2007 | 10:16 AM
kraylon's Avatar
i would do a tranny flush if you have not done one in a while i have a manual and i had an issue with it not wanting to go into first or second easy so i had the tranny fluid change with royal purples syn-gear and it goes into gear like a hot knife though butter and on my wifes camry which is an auto it started to slipp alittle so i had it flushed and filled with royal purples max gear and it was like a whole nother car after, so i would try that and see if it takes care of you problem
Old Aug 23, 2007 | 10:28 AM
brrman's Avatar
There was no 2001 CVT - only 2002+.
Old Aug 25, 2007 | 04:26 PM
apr_a4's Avatar
any help ?
comon i thought this forum ahd tech's
Old Aug 26, 2007 | 08:50 AM
david9999's Avatar
Could be a lot of problems.
Find someone with a real vagcom and check for codes both in the engine and transmission.
You don't mention how many miles on the car.
If you are truly having transmission problems, dropping the pan and changing the filter and fluid isn't going to hurt.
Old Aug 26, 2007 | 06:17 PM
apr_a4's Avatar
it has 84k, i talked to my autos teacher and he told me that it might electrical he said that that the tranny computer is telling one of the clutches to release but they do it to late (one clutch released one didnt) and since it happens once in a while it could be it
would a generic scantool do it
i have acesses to alldata.com
Old Aug 26, 2007 | 06:37 PM
auditech79's Avatar
Check fault codes as david9999 said.
The three most common problems you're gonna find is the fluid is old and is messing with the valve body shifting gears and or clutch packs.
The TCM or tranny wiring harness has a short.
Lastly the torque converter clutch is sticking/ and or stuck open.
The last two most likely will throw a fault code though.
Keithmanton
Jan 30, 2012 09:08 AM
coolrunnin
Jan 28, 2012 11:51 AM
speedfreak
Oct 25, 2009 01:58 PM
cstarky15
Oct 13, 2007 12:45 AM
Edward L.
Dec 24, 2006 10:58 PM
