Turbo wont start!!
Old Nov 1, 2013 | 09:23 AM
andrei.varcus's Avatar
Default Turbo wont start!!
hi,
For approx 1 month ive got serious problems with my car A4 2004
My car works perfectly if outside is +12 degrees (turbo works)
But if is under 12 degrees my car turbo doesnt start..car works like sh..t 50-60 total hp
Ive searched in other forums and told me to change the debitmeter...now i've changed it the same.
Ive made a test during 1000-3000 rpm
Here is TEster LOG:
Code:
 Address 01: Engine  (038 906 019 JT)
20:13:31 Group 003: EGR (Exhaust Gases Recycling)
  882 /min  Engine speed 790-870
  280.0 mg/str  MAF (specified) 230-310
  279.3 mg/str  MAF (actual) 210-350
  57.4 %  EGR duty cycle 40-75%
20:13:31 Group 010: Air system (3rd gear - 3000rpm - full load)
  274.4 mg/str  MAF 900-1250
  999.6 mbar  Atmos. pressure sensor -f96-
  994.5  Intake air press. 2100-2600
  0.0 %  Throttle 100%
20:13:31 Group 011: Charge pressure control (3rd gear - 3000rpm - full load)
  882 /min  Engine speed 2850-3150
  1091.4 mbar  Spec. intake press. 2200-2400
  994.5  Actual intake press. 2100-2600
  19.9 %  D.cycle MAP 35-80%
1 Fault Found:
17552 - Mass Air Flow Sensor (G70)
            P1144 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 X X X
Old Nov 8, 2013 | 09:11 AM
M5S5's Avatar
Tech Certified
17552 (mass air flow sensor) = there's your problem!
Dylan Cure
Sep 4, 2012 04:21 AM
Billydakid
Oct 29, 2010 02:40 AM
cwhite08
Oct 27, 2008 07:04 PM
