Turbo wont start!!
hi,
For approx 1 month ive got serious problems with my car A4 2004
My car works perfectly if outside is +12 degrees (turbo works)
But if is under 12 degrees my car turbo doesnt start..car works like sh..t 50-60 total hp
Ive searched in other forums and told me to change the debitmeter...now i've changed it the same.
Ive made a test during 1000-3000 rpm
Here is TEster LOG:
Here is TEster LOG:
Code:
Address 01: Engine (038 906 019 JT)
20:13:31 Group 003: EGR (Exhaust Gases Recycling)
882 /min Engine speed 790-870
280.0 mg/str MAF (specified) 230-310
279.3 mg/str MAF (actual) 210-350
57.4 % EGR duty cycle 40-75%
20:13:31 Group 010: Air system (3rd gear - 3000rpm - full load)
274.4 mg/str MAF 900-1250
999.6 mbar Atmos. pressure sensor -f96-
994.5 Intake air press. 2100-2600
0.0 % Throttle 100%
20:13:31 Group 011: Charge pressure control (3rd gear - 3000rpm - full load)
882 /min Engine speed 2850-3150
1091.4 mbar Spec. intake press. 2200-2400
994.5 Actual intake press. 2100-2600
19.9 % D.cycle MAP 35-80%
1 Fault Found:
17552 - Mass Air Flow Sensor (G70)
P1144 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 X X X
kinnes042
S4
Apr 10, 2013 06:29 PM
Billydakid
Oct 29, 2010 02:40 AM
brit.mike13
Oct 17, 2010 08:26 PM
