turo-back exhaust
Old Feb 23, 2006 | 12:42 AM
LTscribe's Avatar
Default turo-back exhaust
I recently bought a 2001 A4 1.8T and I want to start upgrading. It's stock and I'm thinking I can start with the turbo-back exhaust but I don't know which one is best. If someone can give me some suggestions on which company is most reliable, it would help alot. Thanks
Old Feb 23, 2006 | 12:52 AM
BadLuckAudi's Avatar
Default RE: turo-back exhaust
I dont know if turbo back but you could get a high flow cat or test pipe with a cat back system like borla. I have borla and i love it
Old Feb 23, 2006 | 01:58 AM
LTscribe's Avatar
What about the APR system?? Does anybody have any experience with it, Good or Bad?....at $899, it's worth asking
Old Feb 23, 2006 | 02:11 AM
Dont have first hand knoledge but have heard that its pretty good, but like i said you can get a borla one for less...... techtonicstuning.com is where i got mine
Old Feb 23, 2006 | 02:14 AM
black991.8tq's Avatar
if ur going to pay 899 u should just go with milltek, its the best out there.
Old Feb 23, 2006 | 06:20 AM
LTscribe's Avatar
alright, thanks alot. I think i'll get the Borla cat-back system with the downpipe from AWE tuning for now, but now i'll need a good high flow cat to go with it....any suggestions?? something not too ridiculously expensive. the cat-back with downpipe is goin to cost around $650, so if its around $350, that'd be great.
Old Feb 23, 2006 | 06:56 AM
BaconBait's Avatar
Here's the one I have-
http://www.bahnbrenner.com/media/php...=204&catid=137
It's not exactly in your specific price range, but others are more expensive. Bolts up perfectly with the AWE Borla exhaust. Only complaint I have is that the washers that connect to the downpipe weren't large enough. 15 cents at the local hardware store.
If you plan on doing the install yourself, you might want to invest in a sawzall. The oxygen sensors are 22mm. you can get the special socket made for it or just use a 22mm open end wrench.
Old Feb 23, 2006 | 07:22 AM
LTscribe's Avatar
ok cool....explain what you did with the oxygen sensors, cuz i'm planning on doing it myself and I don't want to have a special socket made
Old Feb 23, 2006 | 09:55 AM
dafrazi's Avatar
You can use a box end wrench instead of an O2 sensor socket. I believe it's 7/8". The front O2 sensor is easy. The back O2 sensor was hard for me to get too. If you don't have a box end wrench get the socket, they are cheaper.
blka3ntx
Mar 10, 2008 04:16 PM
juice88
May 17, 2007 05:21 PM
Dj Spiel
Jun 7, 2006 04:37 AM
npalmreu
Apr 27, 2005 02:06 PM
fresh1
Sep 8, 2004 11:09 AM
