UHHH..
Old Jan 5, 2006 | 05:08 PM
aRIf's Avatar
Default RE: UHHH..
sure I'll help you this weekend.
Old Jan 5, 2006 | 05:10 PM
onepoint8tee's Avatar
Default RE: UHHH..
Would the fuse blow before the headlight in all cases?
Thanks Arif give me a call tomorrow or saturday please!
Old Jan 5, 2006 | 05:18 PM
aRIf's Avatar
Default RE: UHHH..
ORIGINAL: onepoint8tee
99% yes. One thing I did a mistake while I was installing my gauge light cable. I took out the fuse box open the plastic cases and I unscrewed all the screws. It mistake I did was I left the box all open alone and it touch the metal part on the side of the car and I saw a spark. it cost me a fuse to replace. I was lucky nothing happened. If you did a same mistake that I did, you might blown some other fuses. better you check all the fuses if you get a chance. did you check evetyhing in the car (other lights, tail lights, fogs, radio, ac , heater etc..)
I'll give you a call I think saturday after my brother left. You also got my number right ?
Old Jan 5, 2006 | 05:29 PM
Default RE: UHHH..
I need your #, will you PM it to me? I havent checked all fuses, but everything else works.. Ill have to check on the tail/brake lights though. the high beam works in it, but its just the low beam, so i think the wiring would be ok?
Is it easy to take the bulb out and see if it is blown?
Old Jan 5, 2006 | 05:43 PM
aRIf's Avatar
Default RE: UHHH..
so easy to check the bulb
see the something like spring in the bulb... if it is broke then it is death.
Old Jan 5, 2006 | 06:04 PM
dafrazi's Avatar
Default RE: UHHH..
there are at least 2 fuses for the headlights. A mini bus fuse (along the top of the fuse panel) and a regular size bus fuse. The mini Fuse is somewhere in the upper right hand corner. I don't remember where the other is. Search on Audiworld. I think that is where I found the fuse panel layout.
achTTung
Aug 10, 2008 02:34 PM
Karl
Jul 1, 2007 11:59 PM
onepoint8tee
Oct 26, 2006 04:44 PM
S4BURG
Oct 4, 2006 09:09 PM
