Valve Gasket on 1.8T
Old Oct 30, 2006 | 02:59 AM
fcanozo's Avatar
Default Valve Gasket on 1.8T
Hi, guys My 1.8t is missfiring on hard drive RPM but no code, I pulled out the spark plugs to reduce the gap from 0.32 to 0.28 since it's chiped and I did found the Cyl #2 plug full of oil, I'm not an expert but looks like a blown valve gasket.
Is it expensive, any special tool and/or hard to DIY?
Old Oct 30, 2006 | 03:15 AM
fcanozo's Avatar
Default RE: Valve Gasket on 1.8T
Anybody?
Old Oct 30, 2006 | 03:17 AM
onepoint8tee's Avatar
Default RE: Head Gasket on 1.8T
Are you sure what looks like oil isnt actually fuel? If you are missfireing there is unburnt fuel. I would swap the coil pack from the plug that is messed up and see if the problem follows that particular coil pack. Im surprised there is no code.
Old Oct 30, 2006 | 03:19 AM
If there is oil on top where the coil pack sits, change the spark plug/valve cover gasket.
fcanozo's Avatar
It's no fuel, it's oil all around the plug and the coil
Old Oct 30, 2006 | 03:21 AM
fcanozo's Avatar
Is it difficult or DIY?
Old Oct 30, 2006 | 03:42 AM
No, check out the DIY section for an article on it.
Old Oct 30, 2006 | 03:55 AM
fcanozo's Avatar
thank you!
Old Nov 7, 2007 | 02:57 PM
fumoazul99's Avatar
seems like my HG is sweating... is this a comom problem on 1.8t ?
Soravia
Jun 18, 2010 10:54 PM
robert.jones
Dec 10, 2008 08:01 AM
robert.jones
Dec 10, 2008 07:56 AM
jzobie
Oct 6, 2008 09:54 PM
