Valves or lifters making noises?
Old Jul 7, 2005 | 11:56 AM
lidonnit's Avatar
Default RE: Valves or lifters making noises?
EGR valve?... Whats that... I'm having a retarded day.
Old Jul 7, 2005 | 06:02 PM
99AudiA4q's Avatar
yea i know what is an EGR valve im confused it sounds familiar. Today i added some of that Engine Restore oil into my car my friend said it helped him so i went and bought it. Its a blue liquid thats supposed to help with the knocking. But any other ideas can still be used so if any one else knows anything about this i need all the help i can get.
Old Jul 7, 2005 | 08:15 PM
99AudiA4q's Avatar
Anybody?
Old Jul 7, 2005 | 11:42 PM
dafrazi's Avatar
EGR= Exhaust Gas Recirculation Valve
It's parts of the emission system. It allows the car to recirculate some of the exhaust gas to burn off unused feul in the exhaust thereby helping to create cleaner emissions. The exhaust gas is also used to help eliminate engine knock by reducing the cylinder temperature to prevent earlier detonation, otherwise known as "knock". A poorly functioning EGR valve doesn't allow the proper amount of exhaust back into the cylinder.
Old Jul 8, 2005 | 12:47 AM
99AudiA4q's Avatar
Does anyone have a pic and some info on how to check this im not a very expirienced audi mechanic. So can any show me a pic and kind of tell me what to look for?
Old Jul 8, 2005 | 01:26 AM
lidonnit's Avatar
Seriously, I would take it to the doctors just to check out. However, I ask tom ritt about the EGR and where to locate. (he's probably pulled it apart and made one before)
Old Jul 8, 2005 | 02:53 AM
david9999's Avatar
This isn't engine knock. Engine knock occurs under load. Sounds like you are complaining of valve/lifter noise.
Check oil pressure. Depending on where you live, run synthetic 5W/40 oil. Change your oil at most every 5K miles
Old Jul 8, 2005 | 02:54 AM
  #18
david9999's Avatar
[quote]ORIGINAL: david9999
Check oil pressure. Depending on where you live, run synthetic 5W/40 oil or 10/40 oil.
Old Jul 8, 2005 | 09:57 AM
  #19
dafrazi's Avatar
Engine knock most commonly occurs under 'moderate' load but can happen at any time. Valves or lifter noise after running the car at high rpm - sustained 6k per post - can cause excesive heat and may indeed cause engine knock.
akielb
May 16, 2007 10:14 AM
ivanmartinez
Jan 18, 2007 02:35 AM
rnbguy
Oct 7, 2006 08:45 AM
nazifa4
May 30, 2005 11:15 PM
pauldvern
Dec 7, 2004 09:30 PM
