washer fluid tank
yea so my tank dosent want to hold any dam fluid before i rip the car apart is there any plug I should know about, or maybe a gasket around the sensor.. is this common i hate seeing that dam pisser in yellow on my center srean.. its driving me nuts, happend today, might have done something when i was fixing my endlinks maybe?
There are 2 pumps that go into the resevoir which the casings of the pumps can deteriorate and leak. Take out the resevoir and check the 2 pump locations for leaks. Replace/fix. VERY common. Take out the drivers side wheel well and unbolt/unplug everything connected to it (the resevoir) and take out the resevoir- remove the pumps... Mine were leaking bad but the pumps still worked. So I just used some rubber cement/sealant, let it dry and wrapped them up in electrical tape and put everything back together. I did this about a year ago and so far so good. There is a DIY article for it floating around somewhere... Cant remember where.
Lol its funny that you mention that. Because Yesterday My fluid light came on so I stopped by the store and picked up some vac line and some windshield fluid. So today I remount my 007 back to its normal position because having it in reverse sucks big time. After I get done with that I was adding the fluid when I noticed that all of it was pouring out the bottom of the reservoir , so i got under my car again and took off the lower valence and the wheel well. I saw that it was coming from the pump at the bottom was leaking. So i syphened out the fluid so I could reuse it. dried it all up and put some water proof adhesive along with a rubber washer to prevent the leak. It takes 24 to cure all the way. But Ill let you know if it worked for me.
so we did the same crap yesterday..lol thats great.. yea i am going to have to do something like that but first i have to spot the problem i just put a gallon of fluid in and watched it **** all over the ground.. then i got mad and played flag football..
yea when I saw it leaking I was like damn it Im going to have to clean that **** up, so i stuck my oil pan under there to catch some of it. Lucky I changed my oil the other day, and was fortunate to have cleaned it.
mcanedo92588
Jul 1, 2013 11:27 PM
MartinCieslak1
Feb 25, 2011 07:51 AM
Jusaywhat
Nov 10, 2008 11:49 AM
