Water pump replacement?
Old Mar 18, 2007 | 05:49 AM
  #21
zoti's Avatar
Default RE: Water pump replacement?
That is the same guide I used. I did the timing belt for the first time on any car. It's a time consuming job and will take 8-10 hours to complete but it's not complicated.
Dieselgeek.com sells a timing belt kit that comes with two long screws you use instead of the screws that hold the radiator assembly. This enables you to pull the whole radiator assembly about 3-4 inches away from the vehicle without disconnecting the whole thing completely. It saves a lot of time even though you do have to remove the radiator.
http://www.dieselgeek.com/Detail.bok?no=306
Follow the guide and it will be easy. The water pump/thermostat replacement adds about 1-1.5 hours to the whole thing.
Old Mar 18, 2007 | 05:57 AM
  #22
Belligerenceā„¢'s Avatar
thanks for that dieselgeek link zoti, that's a better price for the kit than ECStuning!
Old Mar 18, 2007 | 01:14 PM
  #23
CRAZYHAWK's Avatar
I paid an independent mechanic4 hours labor to do the job.
It cost me $700 with:
timing belt
2 front belts A/C & P/S
water pump, gasket and antifreeze
tensioner and damper pulley
Old Mar 18, 2007 | 02:56 PM
  #24
acetrebo's Avatar
ORIGINAL: Belligerenceā„¢
jesus christ, looking at those pictures makes me really, really, not want to do my timing belt. [:@]
please, somebody tell me that it isn't as bad as it looks.
its definitely not as bad as it looks. Took me about 8 hrs the first time. I am prety sure I could do it in about 3-4 the second time around. There are some good writeups on audiworld.com, in the tech section.
tbenach
Jul 14, 2011 11:44 AM
keld3000
Sep 30, 2010 02:03 PM
spindrift
Sep 22, 2009 11:16 PM
pazo
B8 Models
May 15, 2009 08:00 AM
gmeyer
Aug 9, 2006 03:58 AM
