What do i need? K&N cone filter
Old Apr 24, 2007 | 11:01 PM
duffman's Avatar
Default What do i need? K&N cone filter
i'd like to get rid of the stock airbox of my 99.5 a4 1.8t, and put in a k&n cone filter. what do i need? is there a kit?
thanks.
Old Apr 24, 2007 | 11:46 PM
acetrebo's Avatar
Default RE: What do i need? K&N cone filter
You should search and read the stickys at the top. These basics are covered many times over.
The stock airbox is more than sufficient if you put in a drop in k&n panel filter, until you go bt.
Some do it anyway because it makes the dv more noticeable, but you wont gain anything, in fact you may lose torque depending on your setup.
Someone will probably disagree with me, butI am right. search for the thousands of posts about it, and you can make your own informed judgement on the subject.
Old Apr 26, 2007 | 05:39 AM
less_of_me's Avatar
Curious...why would torque go down? I searched and couldn't find anything.
Old Apr 26, 2007 | 10:50 AM
Amze's Avatar
I think if you do the setup right, and spend the required money you can make a intake/heatshield setup that is more efficient than our stock airboxes... not by much but you'll gain throttle response, and pull longer in the RPM range beause its sucking in more air. Its pretty noticable, well for me the change was anyway
Old Apr 26, 2007 | 11:45 AM
Amze's Avatar
Well if you don't do it right your just gonna suck in more hot air... which in reality makes your car slower
Old Apr 26, 2007 | 01:02 PM
akoby9's Avatar
So instead of typing out a ton here i'll sum it up.... butamaze and acetrebobasically said it
If you get a cone intake you will hear a deeper noise, and your psssshhh from your DV, and will be a bit deeper. However,I did mine a few weeks ago and I think because I was pulling more air I blew a spring in my DV, so now it makes this snake noise... look for my other thread on like the 2nd page on the forums. Its ok though cause I was planning on ordering a forge007...
Main thing though is you need a really good heat shield for this to even be considered. When I frist did mine I didn't have one, and you can tell a MAJOR difference when first accelerating... like it lags. Once I got a good heat shield I think that it works just or close to as well when first accelerating as the stock air box, but pulls harder above 3k rpms.
Basically if you do a cone intake its just for the noise. But I went to autozone and just picked up a packages thing they had there, it wasn't a K&N but just make sure you also get a smaller filter for your secondary air hose.
Old Apr 26, 2007 | 01:03 PM
akoby9's Avatar
^urggg oops I guess on second thought i did type quitea bit
Old Apr 26, 2007 | 01:11 PM
badboi24u's Avatar
i agree with what he just said. i had a cone with no heatshield it lagged like hell but i made a heatshield and there was such a difference.
Old Apr 27, 2007 | 01:05 AM
eurokid's Avatar
so while this is here,,thought i'd ask...what do some guys make their heat shields out of?
Old Apr 27, 2007 | 01:41 AM
akoby9's Avatar
metal/steel/furance insulation/zip ties
jimmysri
Oct 14, 2013 05:48 AM
rb12
Aug 3, 2010 10:08 AM
Dr!ven
Jun 8, 2008 10:43 PM
