What do these codes mean?
i know p0300 is random misfire, p0302-3 is misfire cylinder 2-3
16500 P0116 Engine Coolant Temperature Circuit - Range/Performance Problem A
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2) A
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2) A
not sure on the 2.8l
if the coil packs are similar to the 1.8t i would say you can eliminate p0300-p0303 with buying new coil packs. pretty easy, other codes i am not sure. I bet someone with tech experience could get you in the right direction. sorry i am of no other help
A missfire will cause 02 sensor/cat codes because unburnt fuel is going into the cats and causing freakish readings. Definately check/replace plugs first. Swap the coil packs around to see if the codes follow the coil packs before buying new ones.
