Whats wrong?
Thanks ALOT!!! "Trailboss"....hey man you been very helpful...i appreiciate all your advice and patients...Ill get back to you, once i replace the ICM, hope thats the problem
Remove the ICM i think its two 7mm bolts, take rubbing alcohol and clean the connectors, then clean the metal on the bottom of the ICM. Should be a piece on the airbox too when you take off the icm, clean that too. Sometime it will git a oily residue caked on it.
No problem, hope this works for yah. Still if you can get a VAG it will help alot. You can get them at ross tech
