Where my odometer usually is, flashes 'oil' but there is definitely oil...
Old Nov 9, 2004 | 08:22 AM
chriscollins's Avatar
Default Where my odometer usually is, flashes 'oil' but there is definitely oil...
like the post says, where my odometer is, when i turn my car on, it flashes 'oil' for about 2 min's, then goes back to the odometer.
My first guess would be the obvious, 'i need oil' but i recently got an oil change, and i checked again, and yep, i do have oil.
What does this mean? thanks.
chris
Old Nov 9, 2004 | 08:59 AM
Jestnomen's Avatar
6th Gear
Default RE: Where my odometer usually is, flashes 'oil' but there is definitely oil...
The instrument cluster is programed to display "oil" after a certain amount of miles. Since you have a 97 you have to go to the dealer to have it reset, or buy a VAG-Com and do it yourself.
Old Nov 9, 2004 | 05:54 PM
brrman's Avatar
yeah - simply a preset reminder for an oil change.
Old Jul 9, 2019 | 06:46 PM
Randy Ladwig's Avatar
my 2001 A4 2.8 Quattro had this right after I changed the oil the 1st time... Kept blinking until I changed it again using a high quality oil filter.
The 1st time was just a Fram filter which are junk as far as build and filter quality. (Youtube it) Have had no issues as long as I keep a good filter and synthetic oil.
If you use "conventional oil" you will have the sludge build up and have to flush the engine quite often. (Known Audi V6 issue)
milan2k12
Apr 24, 2012 08:20 AM
beachchair
May 9, 2008 08:10 PM
mack29730
Feb 2, 2007 06:47 PM
xerexb
Oct 19, 2006 03:21 PM
Butch Cassidy
Sep 25, 2006 03:23 AM
