wiring sound system
Old Feb 5, 2007 | 07:43 PM
new2me's Avatar
Default RE: wiring sound system
no a bad rca would though. Or wireing the sub wrong
Old Feb 5, 2007 | 08:00 PM
tank8970's Avatar
one time i was having problems with my ground wire, just having the rca's plugged in would turn either the power light or the protection light on i dont remember which but when if i just moved the ground to a different spot the sub would work, but it was wierd cuz i just moved it but then that ground went bad i just tried the old one again and it worked then after a couple of weeks that one went bad and then i just said f it
Old Feb 5, 2007 | 08:11 PM
new2me's Avatar
I mounted my amp on the underside of the baffle board and used a screw for a bracket that holds the driver-side carpet wall up. Not sure if that makes much sense ill see if i put a pic in my DIY.
Old Feb 5, 2007 | 10:33 PM
steelcitysfinest69's Avatar
try lifting some carpet in the trunk to find some bare metal or under the back seat. The metal cant be painted so you might have to scrape some paint away. drill a whole where the bare metal is and place your ground there. if you are gettin any kind of light you must be getting power to the amp. having your rca's alone will NEVER light your amp. make sure where your ground is, there is a clean (paint free) flat connection to your chassis. it shouldnt be that hard to find a good ground source for your amp.
Old Feb 6, 2007 | 12:55 AM
Zrowcool's Avatar
yeah im going with a bad ground. id say drill your own hole and ground it. Find a good spot of flat metal thats not welded in such as under the rear deck. drill a hole and watch for fuel, wires,etc. sand down to bare metal and put a bolt with a nut in it. Use can use some electrical grease to prevent rusting.
Old Feb 6, 2007 | 01:55 AM
Lazer Viking's Avatar
i ran my remote turn on from the fuse block from a switch source because i didnt have the right wire to plug into my alpine head unit
check to make sure you didnt cross the rca's
and if the grund or the rca's dont work
thennnn idk.. re-wire it
Old Feb 10, 2007 | 06:59 AM
sdsteez's Avatar
ORIGINAL: new2me
how do i know if the rca's are bad? what way could the wires be wrong?
Old Feb 10, 2007 | 07:14 AM
  #18
mack29730's Avatar
do you have a factory speakers with a factory amp that make that happen too
Old Feb 10, 2007 | 07:19 AM
  #19
sdsteez's Avatar
yea factory speakers. i guess i got a factory amp i dont know where it is though. think its under the backseat but i dont know. i just through in a fosgate amp.....
Old Feb 10, 2007 | 12:58 PM
  #20
new2me's Avatar
How are your speaker's wired? Are they single or double voice coil?
If you pinch or yank on the rca's you can damage them. If you have a boom box that has rca input you can see if it gives you sound. Or just use a volt meter.
heywier427
Jan 4, 2010 12:06 PM
MyCrazyCar
Jul 29, 2008 04:47 PM
osterthetoaster
Feb 22, 2008 04:37 PM
crispycream13
Nov 21, 2006 01:13 AM
triguntz
Sep 14, 2005 12:45 PM
