07 A6 rear brake pad replacement
Old Sep 28, 2010 | 04:36 PM
flippu10's Avatar
Default 07 A6 rear brake pad replacement
Hello All,
I'm new to the forum and wanted to get some advice from the experts. I just bought an 07 A6 Quattro. I noticed right away that the brake pads make the wheels absolutely filthy in just a couple of days of driving. I bought some ceramic pads to replace all 4 wheels. I was able to replace the front pads with no problems after reading some DYIs from this forum which helped me a lot. I'm very familiar with pad replacements and have replace quite a bit of them ion different cars. The only difference with the A6 are the retention springs.
I've read some posts that says I need an electronic tool that will retract the rear brake pads due to the e-parking brakes. I don't want to have to spend the money for something I may only need once (pads should last a long time). Is it possible to replace the pads without using this electronic tool? Can I just push/turn the piston back in manually? I have that tool to push it in that I used on my sister's Jetta. Has anybody done this successfully?
Old Sep 28, 2010 | 07:51 PM
jj2345's Avatar
Bump.I wanna know aswell?
Old Oct 2, 2010 | 08:28 AM
flippu10's Avatar
Common now. I'm pretty sure someone must have done this or at least made an attempt. Can you share your experience. I would really like to replace those dirty pads. Appreciate any insights you can provide.
Old Oct 2, 2010 | 12:02 PM
Kevin's Avatar
You need a VAGCOM to change the rear brakes on a C6.
patchelect
Jun 28, 2009 03:35 PM
motorwerks1
Feb 21, 2009 02:03 PM
blackdjone
Feb 26, 2007 12:28 AM
a3square
Jan 28, 2007 05:47 AM
modset
Jan 13, 2007 03:37 AM
