2.7 Engine Removal
Old Nov 1, 2009 | 08:31 PM
Fearthisrc's Avatar
Member
Default 2.7 Engine Removal
Does anyone has a engine removal guide for the A6 2.7 engine.
Would like to make my removal tomorrow as easy as possible.
Thank you guys
its a 2000 A6 2.7T with 6 Speed
Old Nov 2, 2009 | 09:47 AM
Siricospeed's Avatar
Default Engine removal 2.7t
The easiest way to do this is to purchase the manual. I know it is $80 that could be spent elsewhere, but if you get the cd rom version, you can print out the relevant pages, get them dirty, check things off, etc. It will walk you through this process. It is not that hard, but there is a lot of ground to cover. Start with the right tools; knowledge!
Best of luck!
Old Nov 2, 2009 | 10:15 AM
ImTheDevil's Avatar
Do yourself a favor. It'll take quite awhile but can be invaluable if you're not intimately familiar with the entire engine bay. Buy a few sheets of small adhesive tags. When you unplug the first connector, label both sides (engine side and harness side) as "1" and continue on with 2, 3, 4, etc. Later when you reinstall the engine, just match the numbers up and you won't have to worry about making incorrect connections. Do the same for any vacuum lines as well. It'll seem tedious but you'll be glad you did it later.
Old Nov 2, 2009 | 04:45 PM
nothing77's Avatar
Search the B5 S4 forums, here and on AZ, there are lots of posts with details
Just checked my bookmarks and found this, not the one I used but it'll get you in the right direction
http://vimeo.com/5238276
Old Nov 2, 2009 | 09:11 PM
Fearthisrc's Avatar
Member
Okay so the engine is completely disconnected. But it will only come an inch from the transmission and the engine wont come off any more. I watched that video just now and the only thing i didn't do was put it in reverse. I need this engine out now!!
Please call/text me if you have any idea whats wrong 720 560 7168
thank you guys for helping.
Old Nov 2, 2009 | 09:23 PM
Fearthisrc's Avatar
Member
please need some help tonight!
Old Nov 2, 2009 | 10:37 PM
nothing77's Avatar
http://www.audizine.com/forum/showth...ngine+pull+diy
http://forums.audiworld.com/showthre...577529#2187139
I spoke with a good source, he suggested getting the engine up high to clear the downpipes, put the trans on a greater angle, and pull like heck
Old Nov 2, 2009 | 11:23 PM
Fearthisrc's Avatar
Member
Thank you very much, the one on audizine i am probably going to read through, and watch that video a few more times to double check my work and start tuggin early morning. But thank you very much Ryan. Any more info would help greatly though, and would you suggest pulling eng/tran on the allroad or just pulling the engine tomorrow. Because the allroad wont have the clutch crap to worry about. The trq converter just just slide right out on it. Input? Thank you again.
Old Nov 3, 2009 | 06:28 AM
nothing77's Avatar
Pull the engine and trans together on the TIP, the TC actually slides onto the input shaft and turns to lock, I have always found it easier to pull both at the same time.
Old Apr 27, 2017 | 02:40 AM
JohnnyBob's Avatar
Cool S***
Ya know... I was a mechanic at a Ford Dealership for years, you would think I would have known to do this.... So Im guessing Im gonna have a hell of a time when I go to reinstall huh....? Damn my short sightedness, gets me every time... I have the alldata here at the house and it dont say anything about removal, reinstall procedure. All I wanted to do was replace a head gasket for local dealer here and it seems I may have bitten off more then I want or could chew here.... Dude, If ya got any pointers besides that one about "sticky labels" to make this job go faster for me, Im all "eyes on the screen" Brother. At the rate it's goin now I wont get to ride my Harley for 2 weeks or more
EDIT: Ah..... I think I got this, I kept reading through, found the pics and the video ( kinda retro looking but hey it works)
Last edited by JohnnyBob; Apr 27, 2017 at 03:02 AM. Reason: Found My answer's, just didnt continue looking before state a question, not tryin to spam intentionally dudes 8)
rowingdude
May 30, 2014 11:23 PM
AudiA3DownUnder
Jan 20, 2012 04:08 AM
vtraudt
Nov 20, 2011 08:21 AM
chefro
Jun 26, 2011 12:33 AM
keeganalennie
Apr 19, 2009 10:00 PM
