A6 2.7t Crack...
When he removes the tank there will be fluid at the bottom of the tank that will come rushing out of the hole from which the windshield pump was removed. It sounds more like he does have a crack high up in the tank since the low fluid light is not coming on. In which case there will be even more fuild coming out of the pump holes.
Bob
Bob
Back to the OP:
Back in Febr 07, the job was around $ 127 at a Firestone shop (I found this in the car's maint records):
Miscellaneous Check
$ 85 - "MCK & Repair Washer Fluid Leak"
Damaged
-windshield washer reservoir
-windshield washer motor
-windhield washer connections to reservoir
Pump - 34 + tx
Tank
Miscellaneous Check Additional
$ 42 - Additional Labor
with the info from hcaudikeed - just the tank being $ 110, I bet you look at over $ 200 easily if you go to the dealer.
Miscellaneous Check
Damaged
Pump - 34 + tx
Tank
