A6 2.7t Crack...
Old Jan 29, 2009 | 03:24 PM
twinturbomew's Avatar
Hit me up if you need a new one (or new used) a buddy of mine has a smashed A6 2.7T that he is parting out. I can ask him for the part if you wish
Old Jan 29, 2009 | 04:47 PM
NH_USA's Avatar
Hey Bob,
If the tank has a big leak he should not spill washer fluid all over himself.
All My Audi's have the headlight washers bypassed. They are a PITA
Old Jan 30, 2009 | 07:42 AM
bob martin's Avatar
When he removes the tank there will be fluid at the bottom of the tank that will come rushing out of the hole from which the windshield pump was removed. It sounds more like he does have a crack high up in the tank since the low fluid light is not coming on. In which case there will be even more fuild coming out of the pump holes.
Bob
Old Jan 30, 2009 | 08:04 AM
NH_USA's Avatar
Bob,
Your right - the crack is most likely high up so the light stays on.. I was hopeing he would not wet his pants when removing the tank....
Old Jan 30, 2009 | 12:11 PM
chefro's Avatar
Back to the OP:
Back in Febr 07, the job was around $ 127 at a Firestone shop (I found this in the car's maint records):
Miscellaneous Check
$ 85 - "MCK & Repair Washer Fluid Leak"
Damaged
-windshield washer reservoir
-windshield washer motor
-windhield washer connections to reservoir
Pump - 34 + tx
Tank
Miscellaneous Check Additional
$ 42 - Additional Labor
with the info from hcaudikeed - just the tank being $ 110, I bet you look at over $ 200 easily if you go to the dealer.
kenhovington
May 10, 2014 11:39 PM
4ringcrazy
Mar 7, 2010 10:55 AM
Archangel1596
Apr 15, 2009 02:27 PM
dbansal
Mar 26, 2009 10:48 PM
J.James
Dec 22, 2004 08:50 PM
