A6 2000 told timing belt is toast
Old Mar 6, 2012 | 08:04 PM
Cronus's Avatar
Default A6 2000 told timing belt is toast
My old A6 2.8L would not start. The final occasion upon which she fired up the CEL misfire, O2 Sensor errors triggered as she sputtered at idle.
I took her to the shop after doing the basics: checking for voltage, spark but not fuel.
Apparently the timing belt is toast and the engine has no compression. I had the belt replaced at 90-95K and I am currently at 120K. Is the timing belt likely the issue?
The old girl never ran the same after the replacement of the belt. I had major acceleration/performance issues that led me to join the forum. Any chance the job could have been done so poorly that I might have some recourse even though I am outside of the warranty period?
Old Mar 6, 2012 | 09:59 PM
ImTheDevil's Avatar
Sounds to me like it may have been installed with the timing off a tooth - that'd be enough to hurt acceleration but it'd take the belt jumping teeth or the tensioner/idler failing to smash the valves.
Old Mar 11, 2012 | 01:25 PM
Cronus's Avatar
So it turns out the belt "slipped". No additional damage elsewhere. The shop offered no explanation as to how/why this happened. Bad news: had to pay for the labor. Good news: no major damage you'd expect with timing belt failure. Is this something that is even possible?
Old Mar 11, 2012 | 01:32 PM
ImTheDevil's Avatar
If it jumped a tooth, the tensioner would have to be weak and even so, the belt guides near the sprockets are very tight. That means it could happen again. Jumping one tooth won't break anything, but 2-3 teeth is a different story. Personally I'm way more inclined to believe that they screwed up, installed it off a tooth, didn't double check after setting tension, and are feeding you bullshit so they don't have to perform the repair gratis.
Old Mar 11, 2012 | 09:04 PM
M5S5's Avatar
Tech Certified
Just curious , Why no fuel?
Was the check engine light on after the initial timing belt replacement?
I find it hard to believe the belt just jumped. I'm smelling fish!
rbrianpeters
Dec 29, 2013 12:27 AM
wagner1968
Jan 11, 2010 12:47 AM
Mike2000tt
Aug 14, 2009 11:49 PM
transporter55
Oct 4, 2007 07:56 PM
Jamaha80
Aug 30, 2005 01:13 AM
