A6 auto problem
Old Jul 10, 2011 | 03:44 PM
slimboyfat's Avatar
Default A6 auto problem
Hi can anybody help I have just bought an A6 2.8 quattro auto,T reg but it seems to be pulling away in second,and the triptronic mode will not work also it clunks when selecting drive or reverse.
As im new to audi ownership i know nothing about them Can anybody help please.
Old Jul 11, 2011 | 09:55 AM
padog's Avatar
Are all of the indicator lights on the gearshift lit up? sure sounds like your trans is in limp mode. if so you need to vag com it and see what codes are showing also pull up the front passenger side carpet ou will find the trans controller under it in a black plastic box check inside to see if any water has gotten into it as this is the common cause for the trans to do this. If no water damage is present then vag com is needed to start your diagnosis.
tonyhowell1
B7 Models
Aug 20, 2013 04:28 PM
spireite77
May 20, 2012 04:37 PM
slolatino
Dec 15, 2011 10:01 AM
brummy
Feb 23, 2008 12:29 PM
paulrob2808
Aug 27, 2007 04:42 PM
